Is teak oil a black mold magnet?
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
This year, I decided to get rid of all the loose and flaking Cetol I tried before. I decided to use Star Brite Premium Golden oil. It started out looking good, but...
After a summer of unseasonable rain, where we get rain an average of 2 or more days a week, on a fresh water lake, I have battled black mold more than usual.
And the teak is now especially attacked by the mold. So, does the black mold like teak oil? Is this normal?
This experiment has not worked out well. I'm now at the point where I think I need to suck it up and varnish my teak next season, after a thorough cleaning to get the black streaks out of the wood grain.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
I use motor oil for all kinds of wood applications. I have a 12 yr old cedar deck that has had only used motor oil applied to it. It is beautiful and 2x6 lumber has never warped or curled. Chief
Nov 9, 2012
2,500
Try the concrobium mix devised by ThinWater and posted by SeaFuller
The teak oil is food for mildew, so you have to make it toxic with the borax additive. Don't go hog wild, borax is a fresh water bug toxin. A little bit applied carefully is all you need.
Can I just mix borax in with the teak oil? Looks like I'll be testing this soon, to see if the borax will dissolve in the oil. On the other hand, sponging on some of the concoction will be easy enough. I'll go easy on the sponging, as I know the TSP is bad for waterways.
Gunni
Mar 16, 2010
5,937
Do the mix using the recipe, dissolve it into a liquid and put it in a spray bottle. You can use that to wet a sponge or scrub pad. Put it on let it dry. Do not rinse.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
As said, the oil attracts the algae and mold. Best choice: don't use it! Just scrub it across the grain with salt water and enjoy the natural color
JRacer
Aug 9, 2011
1,393
I use "Pure Tung Oil" from Rockler's and have not had any problems with that.
JamesG161
Feb 14, 2014
8,019
Hunter 430 Waveland, MS
I use Borax and a cheaper [non borax] version of this...
https://www.walmart.com/ip/Wet-and-Forget-Outdoor-Mildew-Stain-Remover-5-gal/21903015
I buy it at a local chemical supply house[$12] and they sell it for a Gym cushion cleaner.
My one gallon size has lasted for 2 years and is almost still full. Just one tablespoon per quart of spay on. Not mixed with the teak oil. Surface only, like dusting your furniture, but sprayed on light mist.
Remember both Borax and the Link above dissolve in water
So...
Like the oil, it will dissipate with time on the weather deck.
Inside the cabin, the non borax stays put and no mildew.:)
When we "swab the decks" I put 2 tbs of borax in the soap bucket. Boron is also a needed ingredient for organisms, other than mold, fungus and algae.
Jim...
PS: Black mold on a boat is normally NON-Toxic type.
Sep 6, 2015
110
Unknown snipe delaware bay
Not to be a ass, but my work around was to remove all the wood trim and replace it with azeks. When that was not easy, I stripped and slathered with west system and painted it.
Eric
Nov 9, 2012
2,500
I ordered some Wet and Forget. I'll spray that on the teak and decks, and see if that cuts down on the black mold. Won't be long and I'll be hauling out anyway :(
Jan 30, 2014
7
Beneteau Oceanis 37 Auckland
I can vouch for the Wet and Forget. I really like the bleached white effect that it gives without rubbing. CRC 'Cleanup' appears to have the same effect.
Aug 22, 2017
1,609
Hunter 26.5 West Palm Beach
"Teak Oil" is a generic term that is used to describe a variety of concoctions that a variety of vendors sell for the intended purpose of enhancing the beauty & longevity of teak. The formulations & quality of these concoctions can vary quite a bit. I usually go for the ones that are either pure tung nut oil, or at least have a large percentage of tung nut oil in them. I haven't had any problems with mold.
I've read that tung nut oil penetrates into the wood, then binds with the wood, then polymerizes. Supposedly, this embeds a polymer within the wood & makes it impervious to most things for a very long time. I haven't independently verified the science behind these claims, but the treated wood does seem to get harder & it certainly does repel water. I started out using this stuff on rifle stocks many years ago, then moved on to also using it on boats, maybe 15 years ago. I have been very happy with the results.
Likes: JRacer
