You cannot depend on your hydrometer
to tell you the state of charge of the battery unless you have been reading them since the battery was new, or you have baselined the battery to know for sure the reading at full charge with a known level of liquid in the battery.Consider this: Your battery is fully charged, you take a hydrometer reading and get 1.290. Is that good or bad? The answer is that it depends on the electrolyte level. If the level is down and you fill each cell up to the top, the reading will (after it mixes) probably be 1.260.So don't depend on the hydrometer to tell you much, unless you know a lot about the batteries.Cheers,Bobs/v X SAIL R 8
