I have both a Rocna and a Fortress and like them both. When I had a Fortress on my previous boat, I purchased a Fortress that was equivalent in weight to a standard Danforth that I would have had for that same boat. What this meant was that I did not realize the weight savings that is typically associated with the Fortress--together with the downside of possibly not wanting to set as readily--but instead had an anchor with greater surface area and holding power for roughly the same weight. So my Fortress FX-23 at 15# weighed the same as the 15# Danforth that would have been an appropriate anchor for that boat, but with better performance and at no weight penalty--albeit with no weight savings, either. I found it set quite well, though as with all Danforth-style anchors, I don't think it's the anchor of choice for swinging on a single hook in a 180-deg. shift.My view of the Fortress's issue is that it's relatively light compared to it's projected area. So if you try to back down on it on a kelpy, grassy, or harder sand bottom, it tends to skid before really digging in.
I think that backing down slowly, understanding the bottom type, etc. would make a lot difference.
IN a muddy bottom, a Fortress would be really good, once you set it.
The Danforth, in my opinion, is somewhat easier to set because it is heavier compared to its projected area. It is heavier.
On my current boat (Ericson 26-2) I have a 10 kg. Rocna on the bow, which I think is better for when I anchor on a single hook, and use an FX-16 for my stern hook. I'm happy with both, each for their own purposes.
