E
ed kangas
i went to look at a 22 today...the boat had been sitting for a very long time...the sails..mast and rigging..cushions...and a small outboard were all stored elsewhere out of the weather and i didn't get to see them...here's what i saw on the boat and the trailer... IS IT WORTH FIXING?the rollers on the trailer appear hardened and have "oil canned" the hull up on the starboard side...the winch is a ball of rust...both tires are rotted and flat...rest of trailer appears sound as it is the factory (i guess) galvanized frame...the boat was open...4 inches of water on the sole...i think just aft of the companionway is where the main sheet traveller belongs...that wood is gone...actually no wood on the boat appears usable...forward hatch has only the frame...companionway hatchtop was surprisingly nice...no visible cracks...most troubling was the starboard chainplate...it was "sunk" into the deck and down below i found the wood bulkhead clearly rotted...some stress cracking around the mast step but solid feeling...the guy only wants 700 for this boat and i have no idea how good the keel bolt is or realy much else other than my 30 minute walk/crawl around ...that revealed the list of things i've noted...has anybody ever done a full restoration on one of these little hunters that would care to comment?toerail and deck hull seam felt and appeared solid...deck felt solid under foot...and of course the boat was filthy but under a deep layer of gelcoat oxidation i still found a little "shine" when i "spit polished" a tiny spot...thanks for your input and opinions...
