You could build one with a lower resolution like this.
Have a disc. On the outer edge a ring of phototransistors or photodiodes.
Inside that ring another with LEDs.
A soda straw sitting over each device so that it can't see its companion.
Above that attached to a wind vane another disc with a small mirror.
As the vane turns the mirror reflects light down from each LEC to its companion phototransisitor.
It turns on.
And turns on a corresponding LED on a cockpit mounted display.
Wow what a bunch of wires needed. (just thought of that as I'm writing....geezz what dope)
Maybe have each of the masthead diodes biased differently so they progressively get brighter as you go around the circle, to make the transisitors conduct more/less. And summed out to give you a voltage level dependant on where the vane is and which transistor it turned on.
Resolution would be limited by how many pairs you can fit around the disk.
Just something from my deranged mind.
It turns on.
