Bill
As I've indicated here earlier, I am going to be buying a 320 soon, probably hull No. 148 which is in stock at the local Hunter dealer. It has a 30 amp alternator. Is this sufficient for charging the batteries without having to run the engine for hours while on the water for a week?Also, do I understand correctly that bottom paint is an option?. If so,then the dealer must have ordered the boat with it because the bottom is blue.I have also noticed that there is always about half an inch of water in the bilge where the keel bolts come through, is this normal? The Autohelm ST30 depthfinder on this boat has been upgraded to and ST60 at a cost of $ 321, is this a worthwhile investment?Can anyone tell me what the standard anchor package is on the 320?Thanks in advance for your comments.
