Anemic
The Universal model 5411 is a very smooth running, reliable diesel. It just doesn't belong in a Catalina 30, and the offering was discontinued after 2 years. I believe the 5411 was available in 1981 and 1982. By 1983 the model 20 was standard, with the 25 being the preferred power plant.It produces maximum torque at the upper end of its power curve. If you take into account the HP required to spin the alternator, and mechanical losses to the shaft and transmission, you're likely realising 5 or 6 HP at the prop at cruising rpm. Had one. In a stiff headwind it just wouldn't power the boat more that 2 to 3 knots.
