Irwin
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Internet search could not answer your question. Do you want a bolt on or encapsulated keel? Can you inspect the boat to confirm?
Nov 19, 2013
4
C&C 29 Mark II Deltaville
Accepted offer to purchase. The vessel has keel bolts but the owner a licensed captain claims it is incapsulated. I searched all the available Irwin info on the internet and owner responses and found nothing. I will have to make my own call when the vessel is hauled for sea trial inspection. Thanks for your research time and response. Other than this issue the vessel is in impeccable condition. I have a Canadian GRP moisture meter and it tested exceedingly dry. There are pros and cons to both keel options just never heard of a vessel with both. Thanks again.
Likes: sail sfbay
Feb 21, 2013
4,638
Virginian.......congratulations on your soon to be new boat, if your sea trail and survey goes well......and GRP moisture meter..........that's being prepared!!.
1,155
Hello Virginian,
For what it's worth: We owned an Irwin 31 Citation many years ago. We admired the Irwin 34 due to its extra space and the distinctive stern each boat sported.
RE: the keel....... Our 31 had a bolted on keel. The hull was lightly built and another Irwin 31 (I think a year newer) with which we were a bit familiar had one more keel bolt than ours did. That keel bolt was under the area of the head compartment and the bolt was in the forward part of the keel. When we began to notice an opening of the joint between the keel and the hull at the leading edge of the keel we added that extra keel bolt to our compliment of attachments in the bilge.
RE the 34: Is it possible that the fiberglass exterior of the keel is the "encapsulated" idea the owner is referring to? That covering being described as encapsulated rather than a lead or cast iron keel that is more exposed to the water unless it is painted?
By the way, that Irwin 31 sailed very well at a specific heeling angle which it could find in the spur of a moment!
Jun 9, 2008
1,853
- -- -Bayfield
Depends on the model. The Citations (which were designed to be more performance oriented) had bolt on keels. The cruising models had encapsulated long keels.
3
Hunter 19-2 backyard
People, I am really confused, i looked for keel bolts on my Citation 34 with centerboard, but can't locate them, could somebody to help me find them, if they exist. could somebody send picture where they are. PLEASE!
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
I had a 1973 Irwin 32 and that keel was both encapsulated and bolted.
