Well Don, as they say there is good news and bad news. Good news; standing in your cockpit if you look down and to starboard (right below and forward) where the locker is on that side you will see the holes for the winch. open the locker and stick your head in and you should see it.(or where it should be to be more accurate).
Bad news; haul it to fix the rod is (in my experience) the only way to properly and safely reconnect the delrin rod.
hope this helps.
