It does get confusing, richard. Here's Battery 101
Sailboat power systems quickly get complex, and almost all sailboat owners have to be their own designer, installer and maintainer of just about everything on their boat, because none of us ever won the lottery..... 'cept Fred, I reckon.
The 'base of the pyramid' for sailboats is the battery - they come in various sizes, and types, but for now let's just think of a car battery, sitting in the bottom of your boat.When you're at the dock, you can use a Battery Charger to charge the battery. This will hook into shore power, which is the (usually yellow) cord that plugs into the city power on the dock. The Battery Charger will keep your battery all charged up as long as you are in the slip and hooked up to shore power.When you leave the dock, you have to unhook the shore power, so you need something else to charge the battery.The first option, for most sailboats, is the engine - most engines have an alternator, just like a car does. This includes just about all inboard engines (most are diesel on sailboats) and some outboards as well. The alternator puts out DC voltage (13 to 14 volts, but don't worry that it's over 12 volts, we'll get to that later) right to the battery and charges it. That's fine, as long as your engine is running, but we didn't buy a sailboat to run the engine, did we?Let's say you're sailing on a lake, mostly just for the day. You won't really worry about draining your battery, because you know it's fully charged when you leave the dock, you won't be using much power while you're sailing, and you know you can either run your engine for a while if you need to, or that you'll be back at the dock in the evening to plug into shore power.OK, if you're going to stay out overnight (or longer) you've got to 'cut the cord' and be able to charge your battery without shore power. Your engine alternator works, but it's noisy and it takes a while and diesel keeps getting more expensive, so now you're into your first 'boat trade-off'... (did anybody mention that EVERYTHING on a sailboat is a trade-off?)One solution is: more batteries.Batteries are usually rated by amp-hours - that is, the number of amps a battery can deliver for one hour. Now a LITTLE math:Watts = Volts x AmpsSo, 1 amp at 12 volts = 12 watts. Your hair-dryer takes 1800 watts, so:1800 watts = 12 volts x 150 amps. A battery roughly the size of the one in a car will produce about 75 amp-hours. You're not stuck with the 'one hour', so it can give you:1 amp for 75 hours25 amps for 3 hours300 amps for 15 minutes (.25 hours)The trade-off is that batteries are heavy, costly, and they wear out with distressing rapidity when used a lot. So you need to strike a balance between carrying more batteries, charging them more often, and using less electricity aboard. Finding that balance is a challenge, and it is a continuing one for any sailor who spends a lot of time away from shore power.As Bill Roosa mentioned, there are ways other than an engine alternator to charge your battery: solar, wind, a dedicated generator.... you can even buy a water generator - that's a propellor that you drag behind your boat that spins when you sail and turns a shaft that turns a generator that produces electricty.Continuing with the trade-off theme:Solar is VERY expensive up-front and a challenge to keep pointed at the sun to get maximum output from.Wind generators are noisy, and, unbelievably, only work when there is enough wind and NOT TOO MUCH WIND!Towed generators only work when you are sailing and slow your boat down.Generators are expensive, can be noisy and drink fuel.In summary, if you are planning to be a day-sailor, or weekend cruiser (even extending to week-long trips), or even living aboard at the dock, you'll probably be looking at charging your battery with shore power and engine alternator.Your trade-off study will involve estimating your power consumption (everything from the hair-dryer to your anchor light [12 hours x .5 amp/hour = 6 amp/hours per day when you're anchoring out]), figuring out how much engine running time you can expect (mostly when entering/leaving an anchorage - you don't want to run your engine JUST to charge your battery because that's bad for diesels), and then making sure you have enough batteries available to satisfy your needs.This often involves multiple batteries - some boats have 10 or more. Most sailors keep 1 battery separate from their 'house' system just to start their engine as a safety measure.Cheers,Bobs/v X SAIL R 8
