The scenario. Was doing some engine compartment wiring this afternoon. No shore power to the boat. (None there since Gustav.) Battery switch off. Had the inverter on and a Weller sodering gun plugged into it. Leaning across the engine got a slight shock. Turn off the inverter, no shock. The inverter is a Xantrex 1000, which is about two years old. Have never noticed this before, but it isn't enough to notice when touched with one hand. Could have been this way since installation. But when leaning over the engine, the back of both my arms resting on the engine I certainly noticed it. Went over the installation, and it is by the book. Inverter hooked directly to the house bank, with a seperate ground wire to the block, as per instructions. Should this be considered normal, or is there something amiss here. Certainly doesn't seem right. The shock isn't enough to be harmful, and as stated, can't even feel it when touched with my hands. Some of you electrical whizzes chime in on this.
