Hi All,
It is stated by many companies, and correct using their lab testing methods, that inverters are about 10% inefficient when converting from 12 volts DC to 120 volts AC. I was curious, and had a sinking feeling, that 10% was a very optimistic number when using the general every day items one might choose to use on a boat..
This questions was posed a few days ago in another post so I did a little photo experiment to help show off SBO's new multiple photo features and just how inefficient inverters really are in the "real world"..
Showing off the new "quote" capabilities here:
To accomplish this test I used our 19" Polaroid boat TV that runs on either 12 volts or 120 volts. What I really wanted to achieve was less "lab" or "theoretical" numbers and more "real world" on a device that can operate on both DC and AC and one that would give a steady output from which to measure. I could have used a laptop computer but any one who's used one knows that the current draw is highly variable and NOT at all steady. My Macbook Pro uses between 3.1 amps (with the lid closed) to 7+ amps depending on the software and program it's running. So a laptop was not used because I could not get a steady current draw from it.
To make sure my TV was consuming a fixed amperage I loaded a DVD into it and then paused it at exactly the same spot in the "Elmo" disc of my daughters. All other devices and charging sources were turned off including my solar panel. The Xantrex XBM battery monitor read 0.0 amps before turning anything on.
The on screen shot is showing the TV paused and running off of 12 volts DC:
Here is the Amp Load at 12 volts DC:
This photo shows the DVD paused in almost the exact same spot though this time it's running on 120 volts AC through my larger 1200 watt inverter.
And the amp draw! There is no trickery here and the Xantrex battery meter is not lying. Running this same exact TV on 120 volts AC through a 1200 watt inverter uses 5.8 amps per hour vs. 3.9 amps per hour!!
When compared to running this SAME EXACT TV on 12 volts DC the inverter has a 32.8% efficiency loss or a far cry from the 10% inverter inefficiency claimed by most manufacturers using very non-real word lab numbers..??
Yes, if you're wondering, I do have a lot of junk on the boat! Big deal...
It does make for some interesting experiments though.
For this second test I used my smaller 400 watt inverter. This is the one that I power my laptop and camera chargers with. My reason for doing this test is to show that an inverter sized closer to the load can sometimes be slightly more efficient and that perhaps different brands of inverters can offer slight advantages in efficiency.
Once again the screen shot:
And the result!
So maybe it's not that much more efficient but 6 tenths of an amp hour is nothing to snub your nose at. The 400 watt inverter ran the TV using only 5.2 amps per hour and was a mere
25% inefficient. Again, this is a far cry from the 10% claimed by many manufacturers.
This certainly was NOT a very scientific experiment
but rather a REAL WORLD experiment designed to show what one item, a TV designed to run on both 120 volts AC and 12 volts DC, will do run both ways.
As far as I know I have never seen an item designed to run on both AC and DC tested in the real world on a boat with a real system and not in some theoretical BS mathematical equation that shows a misleading 10% inefficiency!
It is clear to me that if you have the option to buy a device that will run on 12 volts DO IT!!
Inverting power from 12 volts DC to 120 volts AC is a terribly inefficient way to power devices off your boats house bank of batteries! I'm sure inverters vary in efficiency as my two inverters do but I'd be very surprised to see an inverter meets the claims of 10%, in the real world, using the same device on both 120 volts AC and 12 volts DC..
Sorry for the rant!!
Just wondering which one waste more 12 volts using a 12 tv with a converter or
a 120 TV plugged into a 2500 watt inverter built into the boat.
Nick
And the result!
