I have a 2006 Hunter 45 CC with a Xantrex Freedom 25 Charger / Inverter. When running the Inverter, I was told that the Battery Charger should be turned off. So when I used the inverter, I turned off the circuit breaker for the battery charger.
Are others with a similar set-up doing the same thing... turning off the battery charger?
Thanks,
Jeff
Thanks,
Jeff
