Inverter / Battery Charger
Feb 16, 2012
198
Hunter 45 CC Alamitos Bay, Long Beach
I have a 2006 Hunter 45 CC with a Xantrex Freedom 25 Charger / Inverter. When running the Inverter, I was told that the Battery Charger should be turned off. So when I used the inverter, I turned off the circuit breaker for the battery charger.
Are others with a similar set-up doing the same thing... turning off the battery charger?
Thanks,
Jeff
Beneteau 343 Saint Helens, Oregon OR
It probably depends on wiring. I have an older inverter/charger but do not have the charger function enabled. I do have to switch off the standalone charger.
The combined inverter/charger should handle it internally.
Jun 1, 2009
1,852
Hunter 49 toronto
Can't run both
Thanks,
Jeff
If you are running the inverter, the charger is automatically shut off. I assume you are doing this with no shore power plugged it.
On the xantrex, you can either use it as an inverter or charter; not both
Feb 16, 2012
198
Artboas,
Yes, I have added a 3 - position selector switch, that allows me to switch between, Shore Power, Generator, or Invertor. So, to answer your question, when I am running off the Invertor, I cannot be connected to Shore Power. I added this as a safety option.
So I guess that when in the "invertor Mode" there is no reason for me to turn off the circuit breaker for the "invertor" battery charger. Any thoughts?/
Thank You for your Response.
Jeff
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Circuit Breaker
I have a 2007 H-36 with inverter/charger and I think it is the 200 freedom and
it has a remote panel just for the inverter/charge which I thick you have too,the remote panel controls the inverter /charger.
I don't have a breaker for the charger and the charger/inverter is what it says the charger is built in the inverter /charger and don't understand where this circuit breaker is for the charger.
The remote panel has push switch for charger and inverter and yes maybe have seen the charge lite come on when inverter but when not on shore power pushing the charge part just lites up the remote panel to show battery monitoring any time you check it and unless you are on shore power I think the charger does not really do any charging.
So more info would be good and do you have same remote panels as I do.
Nick
Feb 6, 1998
11,714
Jeff,
Be 100% sure this was done correctly, the vast majority of transfer switches I see installed are done incorrectly.
When on shore power AC NEUTRAL and GROUND ARE NOT connected on the boat
When using INVERT AC NEUTRAL & GROUND ARE connected on the boat
When using GENSET AC NEUTRAL & GROUND ARE connected on the boat
Jeff
Many AC panels come with a battery charger breaker and in fact your boat may have come from the factory with a battery charger, and the IC was added later. Best to look at the back of that breaker and see if it is actually wired to something. If it is, find it and discern what it is.
I had one customer who went through two battery banks before he realized his Battery Charger breaker was connected to nothing.... The idiot light came on so he assumed he was charging...:doh::doh:
Dec 25, 2000
5,947
Charger
Hi Jeff, a few years ago I replaced our tired original inverter/charger with a Freedom 25. Did the job myself, basically plug and play. Our boat also has a Genset. Our power panel is set up in a way that allows you to select either inverter or Genset/shorepower, but not both. I let the Freedom 25 determine whether to charge or not and to what level. I leave the charge function on all the time, whether I use the inverter or not. This all seems to work well without incident.
Dec 19, 2006
5,832
Factory
My boat Has inverter/charger and gen all installed at the factory and insisted
everything be added at factory and not added by dealer.
My dealer did want to add some things at the dealership but I said no and had everything done at factory and have never had any problems,I believe I have 2 auto transfer switch one for Gen and I think one for maybe inverter/charger but not sure and have switched from inverter to Gen or shore power and always
been done auto with no back feeding of any kind and I don't have any manual switching.
I am not much of a electrical guy but my system is very involved with extra breakers and battery switch and cross over parallel breakers because of my FP Gen and 2 battery banks which I changed to 1 big Bank and starter battery and than the Inverter/charger.
I do see wiring for a charger from the factory but is not used because I have
a inverter/charger and the remote panel is wired to the inverter/charger and that remote controls the charging and inverter functions and acts as a battery monitor.
I would think if there is a breaker for the charger that that means a separate
charger was installed and than later the inverter/charger was added and maybe that breaker is to the inverter/charger
Nick
Feb 16, 2012
198
Nick
Nick,
Yes I do have the remote Inverter/Charger panel mounted at the nav station. You are correct, when I turn the three-way selector switch to "Inverter", I must also press the touch pad button on the remote panel to turn the inverter on. "IF" my three way selector switch is wired correctly, then I can only be on one of the three power sources at one tine, Shore, Generator, or Inverter.
Jeff
Feb 16, 2012
198
Jeff,
Maine Sail,
Thank you, I will check the wiring. FYI my Hunter came with the "relays", and the small electrical panel from the factory. After many problems with the relays, I had a "Blue Sea" 12-volt / 120-volt panel installed, with circuit breakers to control all 12-volt, and 120-volt functions on the boat. We included a Blue Sea 3-position selector switch for selection; Shore, generator, or Inverter power.
Jeff
Sep 8, 2014
13
Hunter Ledgend We'll see
Hey guys,
The reason to turn of your battery charger if it's setup like mine is because the battery charger is using the shore power (AC) to charge your battery. The inverter takes DC and makes it AC for your use off dock. Turning the inverter on while its hooked up to AC is dangerous to your electrical system and will most likely cause damage, like a fuse blowing or inverter frying. You must shut off all AC input before turning on inverter. Otherwise they will parallel out of phase with one another which is a bad thing (electrical engineer speak). Hope this helps.
Feb 16, 2012
198
What Size Circuit Breaker
Jeff,
Maine Sail,
Regarding this subject. I previously had a 15 Amp Blue Sea Circuit Breaker for the "Battery Charger" circuit for the Xantrex Freedom 25 Inverter on my 2006 Hunter 45 CC.
I have been told that I should change it to a 30 Am Circuit Breaker. Is this correct?
Thanks,
Jeff
