Introducing the fine Vega 1005 s/y Maria
May 12, 2009
57
Hello group!
Having contracted boatitis a couple of years back I started browsing a few sites for used boats. Having a under 10k euro budget I first considered the Maxi 77 and then finally decided the Albin Vega was the boat for me. Being situated in Finland, the Vega population is quite high, especially so in Sweden, where I eventually found my boat.
As the Vega population is quite high, and sailing boats in general more populous in Sweden, I got what I consider a nice deal: 85000 swedish crowns, or some 7900e for a -70 Vega with newish (2001 mainsail, 2006 furlex genoa) sails and a Yanmar 1GM10 (-90) 9.5hp diesel with freshwater cooling.
After a few weeks of emailing back and forth, hiring a surveyor, receiving the report and then pondering over it with my high school swedish I finally decided to buy the boat.
A few things came up with the report, most of them minor stuff you'd expect on an almost 40 year boat. Scratches here and there, old electric cabling (talk about voltage loss... phew), gas system unused for years, a original Vega heater, illegal in Finland these days etc. Also a few more troubling problems came up, of which I have pictures for you as well:
http://www.inttervep.net/~mikko/vega/DSCN0367.JPG
A small crack in the front of the keel, out of which a little water is seeping
The surveyor doesn't think the damage should be very extensive, but suggests sanding down the area and letting it dry during the winter and then painting it up again.
http://www.inttervep.net/~mikko/vega/DSCN0354.JPG
A slight deformation of the front pulpit, including forestay. Probably caused by a sideways bump some time before. According to the current owner it was already there when she bought it, and hasn't really caused any problems.
I guess the metal railing should be removed, the area cleaned up and new gelcoat applied.
The surveyor also checked the hull for any moisture problems, but luckily all values were within acceptable levels.
A few things missing were a Windex and a VHF-antenna from the mast. The Windex we managed to install using a bosun's chair, but the guy up the mast couldn't figure out how to attach the antenna and how to feed the coax cable in the mast. We found the little hatch indoors that you can use to pull the cable in.
The boat is currently just a little shy of midway from Stockholm to Helsinki, in the Åland islands. My aim is to get her to Helsinki in the coming two weeks. Having no vacation at the moment makes this ofcourse a little difficult, but I'll manage it.
Well, that's it for me. As I've been lurking on the forums for a while, absorbing the accumulated knowledge herein, I thought an introduction would be in order!
Mikko
May 30, 2006
1,075
Hi Mikko,Congratulations!
Sounds like you can enjoy your boat right away and you have the whole summer in front of you.roy
Oct 19, 2019
921
Albin Vega 27 Limerick
Mikko - have fun taking your boat to her new home.
Sounds like a great boat...
And you paid a *lot* less than I did.
What is her sail number?
John
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
May 12, 2009
57
Hey there John!
The first part of the trip is over already: In some 24 hours of travelling we got her from Dalarö, Sweden to Marienhamn, Åland Islands. Unfortunately the weather was against us, and we ended up motoring for 22 of those hours. It was a fun trip, nonetheless!
Hopefully I\'ll get her all the way to Helsinki in the coming weeks.
Then begins some moderate renovation: I\'ll go through the electric system and draw up some plans for a new one, and most importantly begin the training for our hairy crew members: two cornish rexes.
Sweden has given up the registration system, so it\'s got some old sail number, and I haven\'t had the chance to register her in Finland yet.
Mikko
Oct 31, 2019
19
Mikko, When I bought my boat two years ago I had
it surveyed and there were also cracks in the
front of the keel out of which drained some dirty
water. The surveyor recommended cleaning out the
crack, enlarging it slightly with a dremel tool,
and then filling in with epoxy. You probably
should also remove the drain plug to insure that
there is no water trapped in the keel.
(Unfortunately I have been unable to work on my
boat yet due to not having retired when I
intended to two years ago and having had a couple
of surgeries during this past year.)
Enjoy your boat.
Peter
At 10:43 AM 6/9/2009, you wrote:
