Gas down below there/There she blows
Ric--I've had my 76 OD25 since new and we cruise all over Long Island Sound. My own philosophy is to drill as few holes through the deck/hull/bottom as possible. I also have a Johnson 9.9 on the back end, and find for most needs the new plastic 6-gal. OMC tank (not Tempo)in the cockpit works well and provides the best margin of safety, being as I like to store gas outside. (Although I would admit the tank sometimes gets in the way.) But, of paramount consideration is safety and that any possible fuel spills or leaks will clearly vent and drain overboard thru the large scupper at the stern. In my own experience, I've had the old metal tanks rust along the bottom seam and on a hot day spill pressurized gas all over. I'll never use them again. That's why I'm sold on the new OEM plastic tank by OMC. It has fewer fittings and is the best made on the market. Fewer fittings translates to less going wrong.....remember Murphy's Law? When we cruise we take a second tank along, nestled next to and tied to the first to prevent movement in rough weather. This is because you can do a lot of motoring in the summer on the Sound to get from one port to another. Otherwise, a single tank does it fine for weekending. In addition, consider the lack of that extra bilge storage (of which you can never have enough), due to a hard-mounted tank down there. Not to mention problems accessing gudgeon bolts, wiring, the scupper hose, etc. Finally, I believe according to both commonsense and USCG regs you'll need to install a full bilge blower system with inlet and outlet vents on the side of the hull thru the side of the deck cap with their hoses extending into the bilge bottom, which takes up further space and allows for additional battery drawdown, which further means you should think of installing a second battery. Now you've really compromised your stowage space in the bilge. Sorry for being negative or overly cautious about it!! So I'd vote and counsel against the below-decks gas.
