Interlake - potential purchase
Apex
Jun 19, 2013
1,227
C&C 30 Elk Rapids
Mom (73 but gets around just fine) just bought a house on a lake. She would like to use the sunfish for sailing, but we have opportunity to purchase an Interlake that I believe would be more comfortable for her. Everything is there with exception of a spinnaker, but it does have floor delamination. The outside skin looks solid, the cockpit floor flexes quite a bit.
Anyone have experience with this boat? Value and how serious the delam is for putzing around? How difficult is the fix?
Thanks in advance for your input!
Aug 2, 2005
1,155
Hello Apex,
The 1968 edition of The Sailboat Classes of North America says the following about the Interlake: "The 18-foot Interlake sloop, designed by Francis Swiesguth in 1932, came before the planing class erabut has survived. Since being converted from wood to fiber glass in 1955, she has become one of the fast-growing classes. With a hard chine and no "freak characteristics", as someone has described her, she has good stability and is a good all-around boat." Vital Statistics: LOA 18' waterline 15' 3" beam 6' 3" draft without centerboard 8" with CB down 4' 8" sail area 175 sq ft (no spinnaker) weight 650 lb trailerable; racing crew two or three
I have never sailed an Interlake, but it looks like a beautiful, dry boat that would be fun for anyone. We owned several Celebrity Class sailboats over the years and the Interlake seems similar although it is described as hard-chined whereas the Celebrity is not. Personally, I would rather see a person "in" a boat like that rather than "on" a board boat like the sunfish.
Will the boat stay in the water? On a mooring or on a dock will put some stresses on the hull and the rigging. A frequent check of the rigging would be in order. We bought one of our Celebrity Class boats cheaply because the mast had fallen and damaged the foredeck while the boat was on a mooring. If the boat is hauled out after each use then Mom will probably need help to do that although 650 pounds isn't too much boat to move. That depends on trailer and launch ramp location. The Interlake will probably offer an opportunity for one or more people to accompany her. Best Wishes.
RE: cockpit sole delamination. Depends on how it is built. If it is laminated with wood between the layers you will have a real project to remove the inner layer and remove/dry the filler. Not impossible, but a serious job. If you can remove the "floor" layer in large pieces you can epoxy those pieces back into their respective places.
Final thoughts: (1) sail the Interlake as it is for a while assuming it does not become waterlogged due to the delamination. (2) Let Mom decide. If she wants to sail the Sunfish let her do it.
Johnb
Hunter 37-cutter Richmond CA
The sunfish is dead simple to rig, easy to sail, weighs in at what 120 pounds, and is eminently suitable for someone who just wants to get out for a while on a nice day. It can be bought and maintained for next to nothing and with a simple rig pulled up out of the water when not in use.
If the water is less than 75 degrees I would equip the user with a wetsuit, good life jacket and whistle cause you never know when a blow might happen.
Apex
Jun 19, 2013
1,227
C&C 30 Elk Rapids
thanks for the replies so far: yes, kept in the water at the dock. the Interlake has locations for a tarp to cover the cockpit, which allows the mast to remain rigged, while the sails should come on/off. We will be doing a sea trial with mom this weekend, and will decide then. Trying to put the Interlake back on the trailer requires a proper launch, we tried (and I am STILL SORE) to beach retrieve....she has a personal access ramp at the house, so perhaps not a big deal, depending on bottom type of the lake.
inprin
Sep 9, 2014
13
Pearson 39-2 New Bern
I sailed Interlakes for 3-4 years. Still popular in Midwest/Great Lakes. It is a double handed boat though. Designed for the Lake Erie chop but raced everywhere. Easy to service/fix. Mine had a small roller furler with the drum under the deck. That would be a nice feature to add.
Aug 2, 2009
651
Catalina 315 Muskegon
You said "the" sunfish, so is do you already own a sunfish? If so, why not sail it, if that's what she wants to do.
I sailed on an Interlake just once a long time ago. Liked it. But I wouldn't care to have one that I have to fix.
Rather than the either/or you've presented, why not try the Sunfish and you can always find a little 16 footer later...O'Day, etc..
