Randy Church
Planning on doing repair work when I get back from deployment next year since the boat won't be going in the water. Typical water damaged areas, floor, shelf, bulkhead. Previous owner put high gloss varnish on everything, which I hate,and would like to remove. Any thoughts on stripping areas not needing repair and then blending in with new repaired areas and is it teak plywood they used back in 1984? Last, the white finish on the plywood used in head and next to small sink is peeling off everywhere. Any ideas on refininishing those areas especially in the head?Thanks,Randy ChurchIraq
