Once you have shaped these panels to fit, you can lay-up your own fiberglass/resin backing to make these panels more rigid - or glue to a marine plywood.
Be sure to allow for added design thickness the backing requires. Also, the reduced flexibility caused by a rigid backing will show scuffs and surface cuts more readily, as the panel will not deform at minor impact.
