Interior leak
Feb 24, 2015
13
hunter 34 holliday marina
My 1983 Hunter 34 seems to be leaking into the interior from around the area of the side stays. Any ideas?
Hunter 34 Herrington South, MD
Mine turned out to be the ports. Recaulk both around the edges and the joints between the inner window and outer frame.
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
Both sides or just the starboard side? Because of the built in stbd list, that side is the origin of most leaks. Are you getting any moisture in behind the reading light on the stbd side over the most forward seat at the dining table? If so that seems to come from clogged drains under the covering over the companionway hatch etc.
Feb 24, 2015
13
I'm seeing damp wood and water stains on both sides, inside of the most forward storage area, behind the sliding plexiglass doors that are above the table and sofa. No drips or visible water outside of the storage areas.
Jun 3, 2004
890
I have some evidence of leakage in that same area but only on the starboard side. I have always put it down to water collecting under the seahood. If it is showing on both sides maybe more likely window related.
Feb 24, 2015
13
Thanks for your input!
