E
Ernie
Hi,I was just down to check on my boat the other day in preparation for spring commissioning. I noticed that the bottom paint on the port side looks very good, while the starboard side is peeling and falling off. I can't figure out what could have caused this. Both sides were painted at the same time in the same weather conditions.As background, about three years ago I stripped all the bottom paint of to the gel coat using "Peel Away". I applied three coats of Micron Extra. It worked out great all summer, held up fine for winter storage in the water, and only needed a good powerwashing in the spring. The following winter it was again stored in the water, and when hauled for cleaning in the spring, was given another two coats of Micron Extra. It made it through the summer fine, and this winter the boat was stored out of water for repairs that couldn't be done in the water. As I stated earlier, this spring the paint is coming off the starboard side (right down to the gel coat), but the port side is fine.The only factor I can think of that might have anything to do with it is that in the summer the starboard side is in the sun at dock while the port side is in the shade.Does anyone have any idea what's causing this and how to remedy it?ThanksErnie
