Interested in removing/replacing/modifying my holding tank
Dec 1, 2016
2
Hunter 27 Edge Aqualand Marina Lake Lanier
I have recently purchased a Hunter 27 Edge and am replacing the marine tolit with a composting one. As such I will not need the holding tank and am curious on what can be done with that space. Ideally I would convert the holding tank or at least that space to an additional fuel tank. Anyone have any suggestions or ideas if this is possible?
Jul 7, 2004
8,525
Hunter 30T Cheney, KS
Depends on how you use your boat. Could be an extra fuel tank or freshwater tank or just extra stowage. I know nothing about composting toilets. I know it takes a long time to compost organics in my backyard composting bin.
Dec 1, 2016
2
At this point I probably do a bit more motoring than I'd like but as such the additional fuel would be most useful.
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
Isn't the holding tank part of the toilet on the H27 E? if so it would be below the engine, if that is the case then I don't believe that the area could be used for fuel unless you add a pump. There is also the added hazard of having fuel below in the cabin area, not sure I would want gasoline in there.
