Insultation.
ibDoug
Jan 17, 2015
5
Hunter 380 San Diego
Hello all,
I am wondering if anyone can tell me if the Hunter sailboats, specifically the 356 and the 386 have any insulation built in. I am interested in the boat but would need to do some cold weather cruising.
Thanks,
Doug.
Apr 11, 2010
998
Hunter 38 Whitehall MI
I seriously doubt it unless it was a retrofit, a custom job or a high end custom boat.
I've had four boats, an S2, an O'Day, a Catalina and now a hunter 38 and no insulation on them.
Production builders are targeting a price point to the penny and the cost of insulation would most likely not be in the cards in those cost models. Especially since the majority of boats are warm weather used.
KD3PC
1,069
boatless rainbow Callao, VA
No built in insulation.
Unless a PO did something to the boat.
There is some "art" in insulating the boat, so as to keep condensation and dampness from become more of a problem, than it needs to be.
Mar 3, 2003
710
Hunter 356 Grand Rivers
No insulation in my 2003 356. The Marine Air works well in 40 - 44 degree water, below that I don't have any experience. I cruise in late fall and early spring. I have a generator so when I am not at the dock I run it and the HVAC continously. Once the boats surfaces inside get warmed up and you keep the HVAC on, it is good to the high 20's outside and maybe lower. It was 27 this morning when I got up and the boat was comfortable. During the night, it got to the low 20's.
Water temp was 44 last night and the boat was 45 inside when we got there at 9 PM and we stayed at the dock, plugged in. By 10, it was at 72, but the interior was still cool due to the cold surfaces. This morning, the chilled surfaces were warm and by late morning, was very comfortable in sunny 38 degree temps. I have a full enclosure and that keeps the cockpit warm when the sun is out and also helps warm the cockpit fiberglass. It took a few hours for the rear bedroom to get to ambient temperature and we had some extra blankets. We were very comfortable during the night and by this morning, the bedding was fully warm. If we had been out cruising, we would have had the benefit of the heat from the generator. Mine is located in the port lazarette (5KW Northern Lights) and that helps heat the foot of the bedroom.
Don't know how cold waters and temps you plan on cruising in, but I strongly recommend a generator, enclosure, autopilot and handheld AP control. On really cold cloudy days, I stand watch in the companionway and use the hand held autopilot control to steer. I keep the slider tight against my chest, wear a heavy coat with a hood and the heat rising knocks off the chill. I am also behind the dodger and I stuff small towels in the holes where my furling lines come through the dodger. You are also over the engine and get the benefit of the heat off it too. The interior stays pleny warm in this scenerio. Those few things make all the difference in the world for comfort. I have sailed in 25 knots at 40 degrees on a sunny day and been comfortable. Returning last spring up the TennTom, left Midway Marina one morning at 27 degrees, but we had been on the boat for about 3 weeks by then and the interior was very comfortable and after a couple of hours and sun, the cockpit got up to about 50 in the enclosure.
Mar 20, 2004
1,753
the only insulation, such as it is, in the 356 is the hull is foam cored above the waterline and the deck is cored with plywood.
We cruise in Maine and the water's pretty cold. Our reverse cycle mermaid system keeps the boat quite warm in the spring and fall. As Jerry said, a dodger and full enclosure is well worth it
ibDoug
Jan 17, 2015
5
This is good news and the help has helped me to make up my mind.
Thanks again to yourself and all.
Doug.
jwing
Jun 5, 2014
503
ODay Mariner Guntersville
Based on the thread title, I was hoping for some graceful insults. Like:
“I am enclosing two tickets to the first night of my new play; bring a friend ... if you have one."
— George Bernard Shaw, playwright (to Winston Churchill)
"Cannot possibly attend first night; will attend second, if there is one."
— Churchill's response”
― George Bernard S
