I CURSE the HAMMERHEADS who installed the thru-hull instruments where they either could not be removed without a haul-out (depthsounder), or without a skinny-armed octopus, (knotmeter)!! The former is oozing water and the stringer against which it is located blocks the internal "bar nut" from tightening. Epoxy, here I come, with a prayer that the water has not found its way into the fiberglass hull!!!... Sympathy is what I need right now..
