Instrument Panel
A
Al
One of the gauges on my instrument panel is not working. I have tried to check it out from the lazarette and don't see anything wrong at this point. Any suggestions would be appreciated. Thank you, Al
What gage is it?
What boat? What engine? That kind of information would be helpful for us to help you.
Joe
Jun 1, 2004
8,220
did you check the sensor?
what about continuity?
Joe
Jun 1, 2004
8,220
universal m-18
try this: http://www.marinedieseldirect.com/universal/200157/universal-owners-manual-m-18-specifications.html The sensor or temp sender is noted on the lower picture. it's on the housing between the by-pass hose and the coolant air bleed. google is awesome still having trouble? Okay, looking at the website's wiring diagram (link below) I see the temp gauge and temp sensor are connected by a tan wire through the harness. #8 on the diagram... just locate the engine side of the harness and follow the tan wire to the sensor. Test the continuity through all connections to the gauge. You can purchase a simple continuity tester, with instructions, from any auto parts store for a few bucks.
