Instrument Panel cover or shield.
779
Hunter 35.5 Legend Lake Travis-Austin,TX
The clear plastic cover/shield over the "instrument panel" for the Yanmar (tach, warning lights, key switch, buzzer) on my 35.5 is weathered to the point of being almost opake. Not scratched, cracked, etc., just very "hazy". When wet with water on both sides from cleaning it looks almost new and clear. Isn't there a polymer conditioner, wax, cleaner that will fix it up for awhile? Seems I've read somewhere about a treatment for plastic windows in dodgers and/or bimini surrounds that might do the trick. Any experience with this out there?
John/Illinois
Buffer
A simple buffing will bring it back. If you have exquiment and a little experence it is a DYI. If not, take it to a glass shop and have it buffed. This should be less then $20. Ask around, many vocationa schools or high schools will also have this equipment,
jimq26
Jun 5, 2004
860
Use 303 Protectant - available right here!
go to their website and you will find solutions for exactly what you describe. The chandlery here has it in stock. 303 Aerospace Protectant cleans up Plexiglass! Plexiglass is a term used loosely to refer to several “hard” clear plastics used in lieu of glass, two of the most common being Lexan® and acrylic. You see this material every day. The enclosures at the bus stop; the windows on subway cars, buses, trains and aircraft; the windshields on race cars; the domed vent covers on the roof of a motor home or travel trailer; the clear panels that keep party-ers from falling out of the sky boxes at football stadiums and protect fans from 100 mph hockey pucks; a motorcycle’s windshield, the visors on fireman and motorcycle helmets…and a thousand other uses.
Sundance Sundance 20 Weekender Ninette, Manitoba, Canada
DIY
Further on the DIY solution, start with 600 grit paper then move t0 1600 then 2400 or emery cloth (also called crocus cloth) with rubbing compound. Failing that try a small corner with toothpaste and your dremmel polishing attachment. At this point you have very little to loose by experimenting.
Ross
Jun 15, 2004
14,693
Not to make things complicated
but the buffing compounds sold for automobile finishes are just about right. 600 Grit will give you the most wonderful ground glass opaque finish that you could ever hope for. Get the liquid compounding material and follow the directions.
JoeB
Jan 23, 2007
22
Oday 240 Carlyle IL
becareful
Just becareful ours "was" the same way and we tried to buff it and it broke due to being so brittle from UV exposure.
Nov 26, 2006
381
Hunter 31 1987 Fly Creek Marina Fairhope,AL.
glazing problem
Be carefull but if you mix baking soda and water to form a paste, you can bring it back i believe. I have used this method on both eye glasses and watch faces with good results. good luck
Aug 19, 2004
239
Hunter 35 Vancouver, BC
Cleaning Clear Plastic
Meguiar's have variety of products for marine applications like this. In my experience they are not cheap but the quality is excellent. See the link. Neil
Jan 27, 2007
383
Irwin 37' center cockpit cleveland ohio
describe it
I have some plexiglass in various sizes and thicknesses that are scrap. If the piece can be replaced easily, then measure it up and let me know and I will send you a piece. Tom H tho52mas@aim.com
barneyflynn
MAKE A NEW ONE
Look up plastics in the Yellow Pages. The supplier may be able to fabricate the piece for you. I did this with a Hunter 30 which has an angled cover for which the supplier did the bending and also the drilling ($25). I also had a cover for the keyhole fabricated which is a a round piece 0f 1/4" x 4" ? red (harder to lose) plastic that pushes in snugly. ($20). If I did it again I would use a smoked plastic to hopefully cut down on the UV. Definite improvement on the OEM.
