Installing Stereo Speakers
K
Kevin
I have a Hunter 340 with the fiberglass arch. Has anyone installed stereo speakers in this type of arch? How did you do it? Thanks!
Padozary
In the process
I have run the speaker wires from the NAV station to the starboard locker. I am at the point of drilling a hole (from inside the arch through the base into the locker), to pull the wires into the arch. however I am not sure how/where to do this since several backing plates are in the way. Access to drill is very tight and I am also concerned about drilling a hole through a stress point. It may be no big-deal, I know several boats that have done it, I am just being carefull. My intention is to install 5" speakers in the access ports. good luck, Paul
