E
Ed Schenck
I just finished the installation of one lonely 5x12 NFM bronze portlight. Do NOT undertake this project unless you possess a lot of time and patience. Actually one of the 7x14’s is in the hole but only screwed in place until I have time to drill the holes and caulk it. I used one entire tube of Life-Calk on the 5x12!But if you do decide to invest here is the rest of the story. The NFM 5x12’s fit pretty well for replacing the smaller ports. NFM’s instructions lay everything out except how to make the hole the right size. For the remaining three I will add a 1/4" inch thickness of plywood to the bottom of the hole between the two drains of the spigot. This will save caulk. You have to glass in a couple of pieces of wood anyway to fill in the drain cutouts for the original ports. The spigots for the forward ports should be 1.5 inch. You can only get 1” and 3/4" bronze bolts. The 3/4" bolts only catch about one thread so I will cut some 1” bolts to size. The 1” bolts are too long to clamp the 5x12 ports. The bolt size is dictated by the length of the boss that is on the outside frame. They are about 3/8” deep which requires countersinking the holes from the outside. I used two screws from the inside to hold the port in place. Then I drilled from the inside using the actual port as the template. Be sure to drill square to the frame so that the outside frame will line up. Then countersink from the outside. Now you are ready to see if the bolts all line up before you get caulk all over everything. Once you know that everything lines up you are ready to fill all the voids with caulk and bolt together. Bolt loosely until the caulk sets. Now tighten everything and you should have a good seal. I was advised to not try to clean anything until the caulk was set. The 7x14s are more of a hassle(is that possible?) because the hole is too long. Now they make a 7x15 but it’s too late. So I had to glass in an oddly shaped piece of plywood on each end. And the spigot drains will not fit until you cut an indentation for them. Naturally they don’t fall in the same place as the original drains. Those still have to be filled with a couple pieces of wood and epoxy. Since I am doing the epoxy work anyway I mix enough to seal the entire plywood edge of the holes. Otherwise the big ports go in just like the small ports. The spigots are 2" on the 7x14s because the cabin is thicker in the main salon. I’ll post some pictures of the next one.Now if you have read this far, still want new ports? I only spent the money because I really want to go offshore. Besides, my old Gray portlights are in poor shape. But they never leaked. Go figure.
