Head replacement-Compact
My C27 (74 model) also has the Compact head, which is also giving problems. Specifically, mine is apparently leaking air into the intake system or pump, which causes the pump to lose it's intake prime. I installed a "T" in the middle of the intake hose with a length of hose and a funnel attached that I can seal off, which allows me to pour some H2O down into the intake line, restore the prime to the pump, and use the head as normal. Works OK but keeps the prime only for a day or two, and is a pain to do each time you need a wet bowl flush. I also looked at replacing the whole head, and found a Jabso head at West Marine which has bolt patterns and size pretty close (but not exact) to the old Raritan. You can intall an inspection port in the front part of the platform the head sits on in order to reach the area to tighen the bolts on a new one. Haven't doen this yeat, but I probably will when I get tired of priming the head all the time. GOOD LUCK!
