Installing Lewar folding wheel on Hunter 310
Dec 27, 2013
2
Hunter 310 Sydney
Hi, I own a 1998 Hunter 310 as of late last year, which I believe is fitted with the Edson Pedestal and steering.
I measured the wheel at 32" and would like to replace it with a similar size Lewmar folding wheel. Although I didn't realise their were different shaft types.
Lewmar sell a 1" tapered wheel and also a dual hub version (1" tapered and 1" parallel).
The dual hub obviously a lot more expensive, so I don't really want to spend the extra money if I don't have to.
Have already asked Hunter Marine (don't have records, but think it was not tapered), Lewmar (say it should be parallel shaft and I should buy the dual hub) and Edson (say it should be tapered, but I should take the wheel off and check)
As none of them give me much confidence, nor am I very confident of pulling the wheel off, or knowing what to look for, but will try if have to, I would like to know if anyone has already fitted one to this model and can confirm which shaft type I need?
Or is my only option to go and pull the wheel off? And how difficult is that?
Also, should I stay with the 32" wheel or go one larger? As some recommend larger when changing to a folding wheel.
Hunter 29.5 Gloucester, VA
I have a 40" folding Lewmar on my 29.5 and love it. You can sit way low and still reach it, or on calm days lay back and steer with your toes. It folds up and leaves plenty of room. I had a 42" Edson wheel but it took up way too much room.
marian
May 21, 2010
47
beneteau beneteau 351 Penetanguishene
One nut and the steering wheel and is of. If it is hard to pull off, it is tapered, :), swing side to side. Keep an eye on the key after you pull the steering wheel.
Marian
Nov 17, 2011
69
Hunter 306 Chester Basin, Nova Scotia
I installed a folding 40" lewmar on my H306, very pleased. Went up from a 36" stock wheel.
Oct 29, 2005
2,366
Go for larger steering wheel. 36" or 40". You wont regret it. As for hub, you'll have pull the wheel to be certain.
