A
Anthony Bavuso
Greetings,Has anyone with a yanmar type B control panel installed an engine hour meter? Where did you get your ground?The hour meter instrument has two inputs, +12VDC and ground. I can easily attach the +12VDC to the ignition switch terminal. But my problem is I don't know where I should get the ground from.I could for example cut the ground conductor going to the tachometer and splice a 3 way butt crimp back on and then attach the 3rd conductor to the engine hour meter. Or I suppose I could run a whole new ground conductor all the way back to the electrical distribution box. Any suggestions? Thanks.
