Installing an in the hull transducer
Nice catch @Mike Oldak . When you stop and see it in real life it's not that big a deal as long as the bottom is realtively horizontal.
IMO, a simpler way of looking at this error in depth is to go back to basic trig :
Just multiply what you're seeing on your depth instrument by the cosine of the angle of your transducer face to horizontal (which never changes) and you'll have your true depth, in this example COS 20° = 0.94.
And that assumes a worst case scenario of your transducer’s acoustics being perfectly directional. Airmar’s DST800 installation instructions say “Best performance on hull deadrise angle through 7°. Accommodates up to a 22° deadrise angle.” I’d take that to mean the signal transmission and detection operate in a 7 degree cone, so you can subtract 7 degrees from the actual deadrise in your cosine calculation (if all transducers have a similar beam pattern).
The OP’s case is probably on the more extreme end of installation locations. 22 degrees in one axis and 17 in the other is a net deflection of about 27 degrees (according to my friendly AI helper). Subtracting 7 degrees for a transducer’s acoustic cone leaves us with a 20 degree angle to compensate for (when the boat isn’t heeling). The OP has a Hunter 34 in the Chesapeake, so he probably has a shoal draft of 4.25 feet. The transducer is probably mounted 1.25 feet below the surface. So when the boat is aground an ideally installed transducer will read 3’, but an uncompensated transducer would read 3.2’. I suppose there probably aren’t too many anchorages or channels where that 3 inches is going to make all the difference, but I guess if you can be more precise why not try to.
MFD
Jun 23, 2016
293
Hunter 41DS Pacific NW USA
I would expect basic trigonometry would apply.
Genuinely curious if there is something special beyond that.
Jan 4, 2006
7,744
A finer point on the original problem.
However, I still wonder why on a 34' Hunter with a likely larger flatter area on the bottom than my H-310 (wider beam), the OP could not find a flatter location for mounting the transducer :
This area of my hull is nearly dead flat and there are numerous other areas just as flat for locating an in hull transducer should I ever need to.
I guess you had to be there to appreciate the full extent of the problem.
Hunter 34 Herrington South, MD
GREAT analysis and deep dive into my H34, but while I totally agree the installation was made on a Forier 26 power boat. I have a thru hull transducer on the H34 since it was install during a bottom painting. This install was on a boat that was recently purchased and would not be hauled this season. I felt a depth sounder inHull was better than no delth sounder for my friend.
Jan 7, 2011
5,953
Oday 322 East Chicago, IN
I don’t care what you say, I am not trying to triangulate the cosine of the anything while trying to navigate through a thin water passage….
Luckily for me, I sail on the Great Lakes, so no tidal issues to deal with, and my hull is pretty flat, and my transducer is mounted in flat spot, so what I read on my screen is pretty accurate!
Greg
