Installing a larger main sail
19
Macgregor 25 Lay Lake
I have the chance to buy a good used main sail for my M25
It measures 25x27x10. These seem to be within inches of the factory sail, any advice out there on this issue?
Jun 3, 2004
1,863
Macgregor 25 So. Cal.
Attach you old stock one and look------
Is there room to raise it higher or will you have to lower the boom or have the sail cut?
Check the out haul.
Will you have to lengthen the boom and maybe run into the back stay or have the sail cut?
Undo the tack and see how much you can raise the sail.
Lower you sail and add the new measurment of the used sail and see if it will fit.
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
suggestion, actually measure from the boom to the top of the mast and mast to end of boom. It really is something everyone should imo. :D
