Installing a in line fuel shut off valve
52
Catalina 310 Gloucester Point, Va
I am thinking of installing a fuel shut off valve between my diesel tank and my Racor Filter. The reason being when changing filters, I do not want to fiddle around with the shut off valve on the fuel tank. If I install it just in front of the Racor Filter, it seems like a easy way to cut off fuel when changing filters...Any thoughts..?
52
Maine Sail...can you recommend a valve that has barbs on each end, so that I can just
cut the fuel hose to the racor filter and insert the valve between the cut hose..
Feb 6, 1998
11,701
Sorry I missed this. Most valves are female NPT and you then buy the male hose adapters to fit the valve and your diameter hose. I don't recall seeing any barb/barb fuel valves.
If this is a Catalina 310 it already has a fuel shut off on the tank..
May 3, 2008
190
Catalina 310 Catawba Island
Shut off valve right in front of filter.
I did this a couple of years ago. Makes changing filters much easier. I used to use channel locks on the input line. This is much better. The fitting screws into the filter and had a barb end for the inlet hose. Brass 1/4 turn shut off. As I recall it was about $20 and I believe I got it at West Marine.
Mar 15, 2011
52
BobJames....i like your idea to put the valve right next the the racor unit, it's a cleaner simpler approach and you only need the valve and one barb.Thanks for the tip
Bob
