I've got an inclinometer on my Catalina 25, and I think it's an essential piece of sailing equipment. Mine is right below the companionway, and I just put it level with the companionway opening. After all, you want the instrument plum with the boat, not the water. You might find that your boat lists to one side or the other.
In sailing, flatter is not always better. A boat with a bit of heel has a longer water line than one that's sitting flat in the water. I used to sail with a guy who said that all boats should heel exactly 17 degrees. I'm not sure that I agree that ALL boats should heel 17 degrees, but my Catalina 25 does best with about 20 degrees of heel--17 degrees is pretty close to right.
I use my inclinometer to assist my crew in "butt management," that is, move your butt so that the boat heels about 20 degrees. Sit on the high side in strong wind, sit on the low side in gentle wind.
