Installation of Simrad WP30CX auto pilot
Bob Carlton
I'm preparing to install a newly purchased A/P on my 1994 28' Catalina MKII. The wheel is on an Edson pedestal. Any advice on the best way to run the wire? Do I drill a hole on the side of the pedestal by the unit and run the wire inside the pedestal? Thanks for any comments.
E
Ed Schenck
Edson wire run.
My own pedestal already had a wire out the back(forward) for the GPS. I first purchased several sizes of rubber grommets at Lowes before deciding on the size of the hole. I drilled a second small hole on the forward facing side, just lower than the other hole. I used one of those heavy rubber 6" couplers from Lowes plumbing. It came with better stainless clamps than the Simrad ones. I cut out a vertical section so that it perfectly fit around the pedestal. It provides a much better clamping surface. But you have to fit the clamps first so you know where to drill the hole, either above or below the clamps.
L
lnranch
wiring
We ran the wire inside the pedestal on our O'Day 28. We drilled a hole in the plastic compass holder and put in a rubber groument we purchased at West Marine. Take care and do not allow you wires to get into the steering cables. Good luck
