Install an outboard engine for 27' Catalina
L
Leon
Where can I find the documents or papers how to install a 9.9 hp outboard engine for my 1982 27' Catalina, which has a dead Atomic-4 inboard gas engine? How much it might cost? And, I also need the advises if I should remove the dead inboard engine once I have the 9.9 hp outboard engine installed?
Joe
Leave it in...
Unless you really need the space. I don't think it is possible to remove without cutting some fiberglass. I don't know of any documents or manuals for your project, but I know that if you buy an outboard motor from a dealer, they will mount it for you. But, I'd look for a used one first. Don't cut a hole in the transom to mount the outboard like the factory OB boats. If you mount it on a bracket attached to the transom you will be fine. Get one that has remote control and electric start. You don't really need a tiller. A late model 2 stroke tohatsu 9.9 with remote and electric will be around $1200. A good place to check is boat dealerships that take units in trade. Mine came off one of those MacGreger 26x things that are supposed to be comination sailboats and powerboats. (BTW, They are neither!) The owner wanted to upgrade to a 50 HP, so he traded in to the dealer. I got it for 850 from the dealer because it didn't have a tiller.... for a better idea of new motor costs, go to www.outboardsales.com
L
leon
Thanks Joe
Thanks for the message Joe, I probably have to cut a hole? And, I might have to remove my dead inboard A-4 engine to reduce the weight? Leon
A
Angelo
Rebuilt it
I just rebuilt my atomic 4 this year and am ver happy with the results. Moyer Marine has everything you will need to do it or have them do it. If the rest of your boat is in good condition - I highly recomend it - less than 5K with the yard removing and installing
