Inside shower & waterheater
Jeff
Has anyone added a inside shower and water heater on a H260? Summer outside showering is just fine but it's getting to cold. The size of the bathroom is about the same as my cab-over camper.
Aug 18, 2006
17
- - Orange Beach, AL
For starters, a HWH, pressurized water system and a larger holding tank for fresh water is required. Add to that the R&R of wall covering materials and a floor drain that would allow showering while sitting on the Porta Potti. Is that about what you had in mind? Is this going to be shore power or genset?
Benny
Don't sound practical.
Other than an inflatable kiddie pool and water heated on the stove the installation of a water heater and shower would be costly and impractical.
Oct 15, 2006
7
Seaward 32RK Lake Pleasent AZ
Thanks for your comments. I mostly camp out and rarely stay in a slip. I found this small tank-less heater that will not need venting, I have an extension box on the captain's chair that I can put a 15lb LPG in. I have already installed a collapsible bladder for an extra 20gal fresh in front of the stock 20gal poly tank and the cold is pressurized already. So I guess the next is to figure the drain system & sealing the floor @ the door. This is the heater that looks like it my just work. What do you think. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=001&item=110044093687&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
