Inside the cabin, I have some areas in the "ceiling" of a sailboat where moisture has caused some corrosion.
The cause of the corrosion has been, in theory, fixed as the various nearby bolts through the deck have been removed and re-bedded.
I have drilled holes from below to allow the moisture to drain and now that they appear dry, I need to put some filler in these overhead areas.
Any suggestion as to the specific epoxy to use and the best way to work in these areas where gravity is an issue in this overhead area.
thanks
john
thanks
john
