Well, it doesn't sound like an EPIRB....
signal, because those transmit on UHF frequencies up to satellites and on 121.5 MHz, sounds more like a DSC 'Distress' message sent via VHF. If I remember correctly, when you activate the 'Distress' function on a VHF DSC enabled radio, it automatically swithes to channel 70 and starts transmitting a distress message in a binary digital format. If the radio is connected to a GPS, the lat/lon info from the GPS is included in the digital distress message. Obviously, this is a handy feature to have, in that in an emergency, you needn't take the time to actually call the CG and manually give them your position. I'm not sure of the CGs' take on their use, but it would seem to me that if you had the time, it would be best to hail the CG on channel 16 and tell them you are going to activate your DSC distress function before you hit the switch, so they will know it is not a false signal. This would also give you the oportunity to give them the nature of the emergency, crew count, etc. Maybe someone with more experience on the subject could clarify the proper proceedure. Did you hear if the CG was able to successfully rescue the crew of the fishing boat?Jeff
