Information is always helpful
273
Oday 25 Alameda
11,772
Wallace..
Wallace or "Boatpoker" as he goes by on Sailnet is a good guy.
I would not loose sleep over your battery situation venting into the boat as I've yet to be on one with lead acid batts that did not in some way or anoteher. As for the charger that is a little more suspect but provided it is operating correctly and not gassing your batts you should be fine till you change it..
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Most batteries on most boats do vent into the accommodation spaces, so I wouldn't worry about that too much. As for the information about not placing the charger near the batteries, this was more of a problem with the older chargers, as they had more of an explosion risk due to sparking than most of the newer, solid state chargers.
Feb 10, 2004
4,253
Hunter 40.5 Warwick, RI
Be aware that CO detectors can alarm due to gassing of charging batteries. I was on the hard one Spring and in the middle of the night my CO detector went off. Nobody around using any engine at 2am, and no other source of CO that I could find.
A call to Kidde provided a list of common household chemicals and situations (like battery charging) that will cause an alarm. This list was in addition to the one that was included with the CO unit.
Likes: 1 person
Jun 4, 2004
273
Oday 25 Alameda
That's the axe the author likes to grind; "They all do that". His point is ABYC standards are what they are and for a reason, and most builders and owners do something else.
Rich is right. We had a C34IA member who was being driven nuts by his detector going off. It took us a week to convince him it was his battery charging that was doing it.
Likes: 1 person
Oct 2, 2008
3,814
Pearson/ 530 Strafford, NH
Hi guys,
Charging a battery puts, what I was told as a firefighter, hydrogen into the air. Folks charging their golf carts in their garage will routinely set off the CO detector. The detectors are cross sensitive to different gasses. I believe Florida has the most of this type of call for service, but the numbers may have changed since my research.
All U Get
Oct 2, 2008
3,814
Hi guys,
All U Get
I did some more research and the sealed batteries recombine hydrogen with oxygen to reduce the risk of explosion. I've only seen two truck batteries that had exploded, what a mess. They either ran dry or overcharged.
All U Get
