Other things to think about
Now that's a great present! Just keep in mind that your choice of furler will impact lots of other areas. Some things you need to know/consider before you choose a furler:The jib will need to have some work done on it to accomodate a furler. The amount of work will depend on the system you choose. If the existing sail is old, it may not be in good enough shape to survive the work, or it may not have enough life left to be worthwhile. You will probably want to have a uv resistent cover sewn on any sail you use. In any case, figure in the cost of the sail work when choosing a furler.You might need a new headstay depending on the system you choose. Also, know the length and diameter of the existing headstay when you shop. If the system you choose requires cutting or replacing the headstay, remember to figure this into the cost.If you want to reef the jib as well as furl, don't forget to account for your existing deck hardware. Many small boats (especially older ones) have fixed (as opposed to moveable) jib blocks. If you are going with a genoa that you intend to reef down, you will need moveable jib sheet blocks.One piece of shopping advice: once you choose a system, shop for it on the internet. I eventually bought my furler from a local sailmaker; I was originally only going to have th sail work done with him, but he offered to match whatever price I could find on the internet. I chose a CDI furler because of the above; CDI's use the existing headstay, and my jib required only to have a tape sewn in the luff.
