Input on Everything
In looking for my cruising boat, I ran across and test-sailed/researched a few Irwins along the way. VERY roomy boats with above average access to everything. Nice deep hull allows lots of "stuff" placed in the bilge. I really like them too and would still consider ownership "for the right price"Disadvantages and problems I found while reading through surveys on a few:Sail poor to weather with full keel; worse than Island Packets even. If you're not the least bit concerned with "speed" or upwind performance, they are, however, very stable. If the Irwin in question has fin keel, forget all of the above. Number one name for Irwins around here: "Party Barge" but that doesn't sound too bad to this bachelor.Problems with rudders both in damage due to depth and construction/loss. The rudder is attached to the boat via regular rudder post (that may be leaky), but also has "horizontal skeg" (I can't remember the proper name for a support that travels from aft end of full keel to bottom of rudder.) Of 6 Irwins surveyed/considered, 5 had a major problem with this area; either damage to rudder or "skeg" or both. Be sure to have surveyor check this thoroughly. As with a lot of boats, at least 50% of the portlights leaked on the vessels I looked at. Several had leaks under companion boards/hatch and caused rot on sole below companion ladder. Two units (a 44' and 46') had leaks along hull/deck joint and since this size boat rarely has gunwales in the water, I suspect it leaks through/under toerails (teak) even during cleaning and rain.Wiring looked above average and layouts are great. Still has the best shower compartment I've seen to date. (46' CC version.) A couple of the owners said things like: "Yeah, we went through a couple of severe blows off the coast of such-n-such; a real Force 8 or 9, and she handled it no problem" but you know HOW us owners are, always bragging about our boats no matter HOW exaggerated.By the way, although no shameless ads are allowed in the forum posts, HOW much you want for your boat or do you plan to keep it for a dinghy? (I didn't see an ad for the boat here in HOW.)
