Does anyone have any tips or tricks for getting up the mast alone. I know ATN makes one, but it is 400$ and I already have a bosuns chair.
Any input is appreciated
Two (climbing) ascenders (@ $70), two locking carabiners (@ $10), a harness (~$50) and a loop of webbing ($5) is all that is required to climb to the top. This would cost you just over $200. But you have to know how to use the gear.
And even if you have all the pieces, it makes a lot of sense to have a helping hand in case you get into trouble (e.g. when you get stuck at the top).
The general rule is that when you work, you never hang yourself off a single line. So you use one line to climb and the other (with the helper) for safety.
I have the ATN Top Climber and purchased it used (but never used, so it was essentially new) so I got a deal on it. If it wasn't half the price as new, I would have made one. The system works well when you are alone (should always try not to be) and can also be used as a traditional chair.I made a system just like ATN and use my bosun chair and got most of the parts on the internet and did have some of the parts and had a canvas shop sew the leg straps from strapping I already had and got used ascenda's.
can you post a picture of your setup? How do you keep the rope "locked" when your reach your working height?I use a 4 purchase block & tackle, pull the top end up with a halyard, Works well fer me! Tom s/v GAIA
