Inexpensive Self Mast Climbing Setup.
Oct 24, 2011
278
Hunter Passage 450 Lake Lanier, GA
Does anyone have any tips or tricks for getting up the mast alone. I know ATN makes one, but it is 400$ and I already have a bosuns chair.
Any input is appreciated :confused:
Oct 24, 2010
2,405
Hunter 30 Everett, WA
There is lots of rock climbing gear out there. Just be sure you know what you are doing. Things like safety knots must be done correctly.
Even with help you can get in trouble if everyone doesn't have their job down. One time my adult son was belaying me and when it was time to descend he tried to reverse the wrap around the winch the wrong way. Fortunately I noticed before starting my decent.
Ken
caguy
Sep 22, 2006
4,004
A friend at our club made a foot board for inch worming your way up a static line with your feet while pulling yourself up using the bosrns chair. I'll see if I can get a copy of the plans.
Aug 13, 2012
533
Catalina 270 Ottawa
Two (climbing) ascenders (@ $70), two locking carabiners (@ $10), a harness (~$50) and a loop of webbing ($5) is all that is required to climb to the top. This would cost you just over $200. But you have to know how to use the gear.
And even if you have all the pieces, it makes a lot of sense to have a helping hand in case you get into trouble (e.g. when you get stuck at the top).
The general rule is that when you work, you never hang yourself off a single line. So you use one line to climb and the other (with the helper) for safety.
Dec 19, 2006
5,813
Hunter 36 Punta Gorda
make one
I made a system just like ATN and use my bosun chair and got most of the parts on the internet and did have some of the parts and had a canvas shop sew the leg straps from strapping I already had and got used ascenda's.
Was less than half the price so shop around for bargains and also looked on the internet at climbing forum's for learning skills and info what and how to go up
and look at sailrite.com for demo of climbing with ATN and I have climbed the mast many times and mine copy works real good but a lot of work for sure
and don't forget to have a backup line for safety and be careful it's a long way down.
Nick
Oct 24, 2011
278
Thanks guys for the replies. I did some rock climbing and repelling in my younger days, but nothing recently. I have a friend at my marina that has a climbing setup that has offered to let me check it out. Definitely have safety at the top of my list.
Dec 4, 2008
264
Other people's boats - Milford, CT
Substitute a prusik knot for the ascenders and the system is cheaper and safer, but slower and more tiring.
http://www.animatedknots.com/prusik...ge=LogoGrog.jpg&Website=www.animatedknots.com
If no one else mentioned it. Using an ascender type device. It is easier to climb if you anchor the bottom of the rope.
Todd Smith
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
ATN also sells a somewhat less expensive version that doesn't include the harness - you provide your own bosuns chair. I used it last winter to install a radar scanner and tv antenna - total 16 solo, unassisted trips up the mast! I rigged a separate static line, and slid a safety line with a Prussick knot attached to a harness as a safety line, up or down as I went.
Nov 8, 2009
537
Hunter 386LE San Fancisco
A SWI-TEC Mastlift has a 10:1 purchase which makes it really easy to solo up and down the mast.
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
I have the ATN Top Climber and purchased it used (but never used, so it was essentially new) so I got a deal on it. If it wasn't half the price as new, I would have made one. The system works well when you are alone (should always try not to be) and can also be used as a traditional chair.
Aug 22, 2011
1,113
or there's always:
tie halyard around neck belayed in Admirals hands - for safety, strip down to shorts or better neked and shimmy on up....
Oct 29, 2005
2,362
I thought ATN has a model of topclimber whereby you use your own bisun chair. It's cheaper than the $400 version.
Oct 24, 2011
278
Thanks Everyone! The ATN unit without the chair is still 250$ so I am going to try and put together something less expensive on my own. I hope everyone has a great and safe holiday weekend! We have a raftup scheduled tonight through Monday and weather is looking perfect!
Tom
73
Lancer 28 T Great Lakes
I use a 4 purchase block & tackle, pull the top end up with a halyard,
Works well fer me!
Tom
s/v GAIA
Oct 24, 2010
2,405
I've actually just used rope, but had help.
I made 2 foot loops and attached them to a halyard.
I attached a second and third halyard to a climbing harness (A boson's chair may work here too).
To go up I stood on the foot loops and had an assistant pull up the slack on the harness halyards. Then sat in the harness and had them pull the foot halyard up. In this way I inched up easily. To go down they just lowered me by easing lines on the winches.
This required 2 assistants (one for working and a safety belay person) but it was pretty easy on the rig and I wasn't worried about falling.
Ken
Jan 7, 2011
5,426
Oday 322 East Chicago, IN
I use a 4 purchase block & tackle, pull the top end up with a halyard, Works well fer me! Tom s/v GAIA
can you post a picture of your setup? How do you keep the rope "locked" when your reach your working height?
capta
Jun 4, 2009
4,904
I've always used a block and tackle set up of at least 5 to one. It requires plenty of 1/2" line and very good quality blocks, but it is the safest and most secure system for going aloft alone, IMO, even at sea. However, when it comes to my safety aloft, I don't think cheap is the way to go. 5 to 7 times the height of your spar plus two very high quality, frictionless blocks are probably not going to come out all that much cheaper than $400.00, but the set up should last you the rest of your sailing career.
