Increasing Turnbuckle Travel
Jan 9, 2025
69
Catalina 30' SR John Wayne Marina, Sequim, WA
If you find yourself with little to no standing rigging turnbuckle travel left on your lower shrouds, here's something I did to gain 0.5" of additional travel. An added benefit is the load is spread over a larger area than just the 5/16" retaining pin.
7,756
Alden 50 Sarasota, Florida
Not sure that’s correct. Same load, same surface area at point of contact. Bearings like this aren’t always built to sustain that type load.
I‘d be more concerned about the constant creep causing the change in distance.
Jan 9, 2025
69
For context; if you've followed my other thread, this particular post is just an FYI on how to get that last 1/2" out of your chain plates. Last summer on the hard I dealt with mast base issue, installed new standing rigging, upgraded chain plates (which are taller than OEM) and over the last two months replaced my compression post.
colemj
Jul 13, 2004
1,187
The clevis pin sees the same load as before. That is a good solution for your particular design, but most stays are mounted to chainplates that have holes sized for the clevis pin. Can't use this trick on those.
I'm confused about how you fixed the mast base, put in higher chain plates, and installed new rigging, but got the rigging length wrong? The better solution would be to cut the swage off and reinstall a new one if the turnbuckle length can accommodate that. Or just replace the stay with a correct length one. It isn't a good solution to have the turnbuckles at their limit - particularly as new wire stretches a bit as it experiences load.
Mark
