A 7:1 scope on a set anchor usually means a good night's sleep. The purpose of a 7:1 scope is to give adequate caternary of the rode to improve the angle near the bottom. This "angle of attach" is improved by using more chain or a kellet weight, as long as the wind is moderate.
Another way to increase the caternary would be to add a modification to a stern anchor. Use the stern anchor to pull the bow anchor rode into a greater caternary. You need two rode shackles, and old heavy duty block, and a length of nylon line smaller in diameter than your bow rode. Shackle the nylon line to the bow anchor chain rode at least the water depth or near the end of the chain, whichever is less. Set the bow anchor as usual, playing out the nylon line. Place the bitter end of the nylon line through an old heavy duty block connected to a rode shackle. Attach that shackle to the stern anchor chain rode at about the same distance from the anchor as done for the bow anchor. Set the stern anchor as usual, and equalize the scopes. Then pull up the nylon line to increase the caternaries on both rodes and cleat it off. You might let out the bow and stern rodes a little to be able to tighten up the nylon line more if desired.
If your anchors are set, this should keep them set, as well as snubbing the rodes as well.
This worked well for me last summer several times, but the winds never really tested it well.
I guess this is a modification of Bahamian mooring. It wouldn't be typical, but could be used when you expect increasing winds, you don't have room for 7:1 scope, or when other boats are stern anchored and you can't get 7:1 scope. How could this be improved?
