OK, but ...
In Critique of the Coastal Cruiser:It’s true - not everyone needs the same boat! The requirements of coastal & semi-protected waters sailing are quite different from those of the off-shore passage-maker. For instance, the coastal cruiser doesn’t require nearly the same quantity of (fuel & water) tankage as an offshore boat. I would, however, expect the quality to be similar.There are, however, some requirements common to all boats. The typical “production” boat is designed and built (mostly) to the “lowest common denominator”, and may lack some of these essential features.Two of the common deficiencies that I’ve observed (in pretty much all boats, whatever their ‘pedigree’) are:1. Poorly conceived & installed cleats (& other deck hardware).You don’t have to be a deepwater world cruiser to appreciate large, strong, well-placed and fastened cleats. After all, a short line attached to a fixed dock, will generate more loading than would (say) a sea anchor or drogue, under the same conditions.2. Inadequate ground tackle.It’s just as important for the coastal week-ender to stay put, as it is for the world cruiser. The coastal cruiser may not need as many anchor set-ups, but those he does deploy must be just as reliable, as those of the off-shore sailor.Maggie & I lived-aboard and cruised a production coastal racer/cruiser (C&C 29) for nine years. While no where near ideal, even after many upgrades & modifications, “Southbound” sufficed. We happily made do, with what we had - the alternative being to stay home & work. So; “... if you can’t have the one you want - love the one you’re with...” - but, please buy her some nice cleats!OMOGord
