The 26D is of course very similar to what I have (26S) and I’m pretty sure that I could have all those people in the cockpit without any problem. The picture just before the accident looks to me like the boat is full of water - listed over to one side, etc.
What if they completely forgot to tighten the ballast valve and also completely left the stopper out of the access hole. With the valve open, water can come in from the bottom of the boat and with all that weight in the back, it can put the ballast tank access hole below the water line. It’s a one inch OD hole - I think it could really be a gusher for filling the boat with water.
Several years ago, I was sailing a Coronado 15 and flipped it - filling the interior of the hull with water. Once the water was in the hull, my weight did almost nothing to act as ballast. The boat was completely unstable - had to get towed in.
Note – my boat has a big warning label near the tank valve and access hole giving clear instructions about filling the tank, closing the valve, having the stopper in place. If this particular issue did have anything to do with the accident, I think they would have had no issue that day if the valve had been closed and the stopper in place.
