I posted this originally in mid-size but thought it was too narrow an audience since there was no reply. :troll:
I finished stripping the bottom paint down to the gelcoat on my 87 31' Hunter. When I got to where the hull meets the keel rust has occurred. I chipped some of the lose gelcoat on the keel away to remove most of the lose stuff. I will grind the exposed iron and the gelcoat a bit so they have a good tooth for an epoxy coating. There seems to be metal on metal where the keel meets the hull (see pic). My question is, what is the best way to prep the exposed keel, especially where there is a slight channel at the seam? Do I excavate the rust to metal or apply something like naval jell or rust-converter? Also is 5200, 4200 or epoxy best to fill the seam?
Thanks for any ideas!
JD
JD
